is it difficult to change a MB battery...
Old Oct 1, 2002 | 09:47 AM
jamesp's Avatar
'97 C 280, '06 ML350
on a '97 C280? the reason i ask is because i took a quick look and saw some wires or coils coming out of the side of it and wondered where the were coming from? just wondered if it took a lot of know how to replace? it doesn't look as easy as my '89 corolla, where the battery replacement is just "plug and play".
Old Oct 4, 2002 | 07:45 AM
MBALEX2002's Avatar
g-wagon
IGNORE THE WIRES. JUST REMOVE THE NEGATIVE TERMINAL THEN
THE POSITIVE TERMINAL. YOU WILL NEED YOUR RADIO CODE
AFTER DOING THIS.
Old Oct 11, 2002 | 12:06 AM
DSMIT's Avatar
1993 MERCEDES BENZ 300TE
IF YOUR BATTERY IS DEAD ,,CALL ROADSIDE ASSISTANCE,,THEY WILL COME OUT SELL YOU A NEW BATTERY,,INSTALL IT FOR NO LABOR CHARGES AND DO IT ALL CORRECTLY,
1-800-222-0100
Old Oct 17, 2002 | 06:57 PM
Dublin's Avatar
easy as pie to replace that battery...I would use roadside myself but if you are going to do it all you need is your radio code and you will probobly have to turn the steering wheel all the way one way and back the other to clear the bas abs warning light. Also you will have to re-learn the one touch window memory by putting each one up all the way and holding the button for 3-5 seconds and the same with down all the way and holding the button. Not sure about your model year but maybe sunroof as well.
Old Oct 17, 2002 | 06:59 PM
DSMIT's Avatar
good point
Old Oct 29, 2002 | 04:56 AM
SLCPUNK's Avatar
On my 94 c280 what is that tube that goes into the side of my battery? It was loose, so I pushed it back on. I've never seen that before, do you know what I'm talking about? Thanks.
Old Oct 29, 2002 | 06:45 AM
bamberger_1's Avatar
'00 S320 W220, '98 A160 W168/ sold in 2005 '86 260 E W124 '90 260E W124
This tube is only to drain gases which maybe generated during charging and other operation conditions such as changing temperatures.....
