Purge Valve?
![Question](https://mbworld.org/forums/images/icons/icon5.gif)
Can you closer discribe whether this purge valve was part of the transmission? If so the $400 sound right since there is quite some labor and material such as transmission fluid involved.
Or what was it if not transmission?
Purge valve is emissions , vac. operated valve between the charcoal canistor and the intake manifold. It is signaled by the ECU with short pulses so as not to affect the idle/intake vac supply.
The common problem is they get dirty and require cleaning or replacement .
About $80,
I just squirt some WD 40 in the hose and re-hook them up. That usually clears them.
They can be tested by simply holding in your hand and feel for a pulse/beat vibration [ oscillations of 4-9 p/sec. ]
About $80,
