speed sensor pulse wire c32????
c32
hi there,im installing a aftermarket navigation and need to find the speed sensor pulse wire for a 02' c32.i've tried the one behind the radio and the ones on the wheels sensor for the abs,but no luck,wondering if someone has installed one,and knows where i can locate it.
thanks
thanks
The safest may is to install an MB CAN-bus adaptor. Because the speed signal goes from ECU to ECU over the CAN-system, this small box fetches the speed signal out of the can signals and gives a useable speed signal for aftermarket non-MB navigation systems. There may be places somewhere you can find a sort of speed signal, but it is possible that ECU's will be damaged if used to connect to something.
The adaptor and the wiring is available at any MB workshop.
Patrick
Patrick
