Automatic Climate Control CLS550
Hi everyone.
I hope this post finds you well.
I have a 2007 CLS 550. I've been muddling through the owners manual and I wonder if one of the enlightened can explain how the automatic climate control functions.
The owners manual says that when the "Auto" button is pushed the car takes into consideration of the ambient temperature, the temperature in the car, and the position of the sun to adust the vent and fan settings to achieve the selected temperature.
The position of the sun? Could anyone elaborate? The more technical the explanation the better.
Thank you in advance.
there is a sun sensor on the hood vent that is split into 4 zones and it measures intensity of the sun ,depending on where the sun is ,it can tell if it is on your right side, and the fan speed will increase slightly to adjust for the radiant heat that comes in on that side ,i hope it helps ,,you will notice this on a hot day more so ,,,,,,
Tcesario,
thanks for your reply.
That helps a little. I thought that those lenses in the top of the windscreen were rain sensors for the rain sensing wipers.
Do you know anything about how the temperature setting works?
Does it have temperature sensors in the cabin?
How does the four zone temperature control work?
Thanks,
Spencer
Tcesario,
Thanks,
Spencer
Thanks,
Spencer
