Please help Keyless go Key problem
Just got my 03 CL55 and i love it.
The only problem is that the car won't lock with the keys. It does have keyless go but i do not have a card just key fobs. The key will work to start the car but won't lock it. Please help anyone. Don't want to leave it on the street unlocked tonight.
thank you
Mark
thank you
Mark
sound 's like the fob batteries need to be replaced ,,,,,hold lock and unlock at the same time for a few seconds and a red light should flash if not batteries are done,if the red light blinks then the car antena is inop ,point the key directly at the driver side infrared receiver in the door handle and hold lock if nothing happens then take it to the shop it will need das to check codes to diagnose correctly ,hope this helps,,,,,,,,,,,,,
Some model key fobs have a small metal skeleton key that comes out of the fob which can be used when the battery is flat. Look for a sliding bit that will release a chrome key which is long and narrow, so it comes out of the fob lengthways.
