Gas
Mercedes says to use 91 and higer because of the compression ratio of the engine, if you use a lower octane gas the fuel will ignite prematurely, robbing horsepower, causing pinging, and eventually causing the other damages I stated earlier. Whoever told you that it didnt matter doenst know what they are talking about.
After owning the car for ~1 year, it required a California smog check as part of the annual registration renewal. Although the "Check Engine" light was operating correctly (come on at engine start, then immeidately go off), it was *not* lit while the car was running. However, the engine would not pass California Smog as the ECU had a couple of registers in a 'Not Ready' state. The engine was very clean burning and easily met all emission standards. But because a couple of the ECU registers were 'Not Ready', the car not pass smog. A technicality, yes - but a requirement none the less.
After 4 months at Claridges MB (now Fletcher Jones MB) in Fremont, CA and well over $3,500 from my pocket, they could not solve the 'Not Ready' ECU register problem. In frustration, the Service Department of Fletcher Jones MB in Fremont, CA went to the California DMV to get me a one-year exemption for the smog test, so at least I could get back on the road.
At this time and purely conicidentally, I moved to Texas where they readily dispense 93 octane fuel. I had the car transported to Texas, in lieu of driving cross country. Upon arrival, my SL600 needed a tank of gas.
After filling up with Chevron 93 octane and driving around town for maybe 40 miles, I took the car in for a smog check as part of the registration transfer process. Although I told the ECU tales to the Smog Technician, the ECU registers were all in a 'Ready' state! The ECU registers have been properly set to 'Ready' ever since and the car has passed smog a second time.
Before anyone jumps on the 'Drive Cycle' routine required after MB service, I did drive the SL600 over 100 miles in California (mixture of city and freeway speeds/conditions) after all the bogus work done Fletcher Jones MB (Fremont). No, the drive cycle requirements had easily been met in CA.
Summary - Gasoline, even premium - in the SF Bay Area was border-line for my engine. I believe the engine's knock sensors (or some other sensor/s) were being activated because the 92 octane in CA was just not quite sufficient for what the engine/ECU were tuned for. Claridge's/Fletcher Jones MB never mentioned octane at all during the multi-month ordeal. By the way, the ECU and all engine components have been all factory; no modifications were performed to them. Not until the car reached Texas where 93 octane is readily available did the ECU 'Not Ready' problem go away. That is the *only* difference between the two locations. The paper-trail of dubious MB work and multiple failed CA smog inspections is a hell of a read!
No, octane does matter.
Also remember that with a non-turbo engine you lose 3 to 3.5 hp per 1000 ft. of elevation gain. Another reason I stick to what MB recommends.
It's true that historically mountain states had lower octane because the effective compression ratio of an engine is lower in thinner air and carburetors had no way to deal with that. But fuel injected cars, like most of ours, account for this via mass air flow and expect the same octane at any altitude. On the other hand, any unmodified car sold in the US will run on 91 octane. If you remap the ECU for a higher octane, you will have problems in some regions of the country.
An imperfect estimate of loss is as follows:
1. Standard sea level pressure is approximately 30 inches of mercury (29.92 to be exact).
2. Each 1000 ft. of altitude gain is about a 1 inch loss in barometric pressure.
3. This approximation is good for altitudes up to about 12,000 ft. It is not a linear relationship, so the estimate becomes less accurate after that. At 18,000 ft. your loss is about 50%.
4. Example: at 6000 ft. elevation, your loss will be about 6 inches, out of a total of 30 inches. This would be about a 20% loss. On a naturally-aspirated engine of 200 maximum horsepower (sea-level rating), you would get about 160 max horsepower.
5. To further confuse the issue, some engine management systems are better at managing barometric pressure changes than others. An engine running too rich at altitude will have further power losses.
6. Turbocharging and supercharging throw another variable into the equation. Turbocharging is best at compensating for altitude, at the price of turbo lag. A turbocharger is free spinning, and could theoretically produce 100% power at high altitude (although there are normally some slight losses). Supercharging is a bit more complicated, since it is driven directly by the engine. The relief valve and controlling software are critical here. Losses might be estimated at one-half of a naturally-aspirated engine; but this varies.
OK, physics lesson over.
Again, turbocharging really helps here. My wife's VW Passat turbo really shines in the high altitudes. Audi, Saab, and Volvo also offer good turbo engines.
Mercedes? The E550 should be plenty powerful, but the turbo Diesels are also excellent mountain climbers.
