Need Help SL 55 Battery Discharged Acid destroyed wiring Harness?
$4000 for the (+) and Ground wiring harness(es) connected to the battery sounds like complete BS. That's heavy gauge wiring with probably only 2 or 3 connections to touch along the way.
You can neutralize battery acid with baking soda and water solution.
Did the acid splash on your trunk liners or any upholstery?
A frozen battery is very easy to overcharge. It is difficult, however, to freeze a battery this time of year, unless the vehicle is parked in the other hemisphere.
