Window Problem
I have not had a chance to remove the door panel yet but I would suspect that there is a problem with the window linkage.
Is there typical cause for such a problem? What things should I look for and how difficult is this repair
Thanks again
This board is great and I enjoy reading all of the wonderful posts.
John
I called to see if my local dealer had a new regulator in stock, since this is such a common part they did have it.
I removed the door panel to check out the problem (to see if I really wanted to do the job) and I found the regulator to be working fine, but the metal frame that attaches to the bottom of the glass had become unbonded. Relieved that it wasn't the regulator I went to the auto glass shop to have this other problem fixed.
I am the second owner of this car so I don't know all of the vehicles history but I found something out today. The regulator on the car has already been replaced, because rivots should have been the were small machine screws, the window must have been replaced because the lower part of the door was filled with glass.
Thanks again for all of the help this site is great!
John
