Paddle Shifters
I have a 2007 ML 350 and two 2008 GL 550s on order. I was at my local dealer the other day checking on the status of the GLs, and while there, I was drooling all over a new SL 55 AMG with the V12. I noticed that it had the silver paddle shifter levers on the back of the steering wheel, instead of the black button shifters that are on the ML and GL. I have always thought the paddle type of shifters look better than the buttons. It looked like the silver paddles went into the back of the steering wheel in the same location with the same footprint as the buttons. Does anyone know if the button type shifters can be swapped out for the nicer paddles? I am pretty technically inclined, and thought that if I were able to get a pair of the paddles, I might be able to take apart the steering wheel and change them. Does anyone know if this would work?
Thank you.
Do a search on the subject and you'll find the links.
Did you do one of these things? I was hoping that there were paddles that fit exactly in place for the buttons.
Thanks.
In the first picture, you will see the collar of the old button as modified to fit the paddle. If your steering wheel and button have the same basic design as the paddle, then I would guess that it is an easier swap.
Another check would be to determine if your buttons simply unclip to remove. If that is the case, then I think you would need to do more retrofitting, as you need a screw to secure the paddles. That screw is in picture two (from the left). It is the black philips head screw to the right of the downshift minus circle icon embedded in the steering wheel. I needed to drill a hole to accommodate.
