Replacement Armored Brake Line
1 Post
Debadged 6-Speed '05 C320 Sports Coupe
The armored front-to-rear brake line on my 94 Grand Cherokee failed. It is not available from the dealership. The local shops would fabricate this, but without the armor.
An on-line search revealed Fine Lines would re-create the original, in either steel w/ stainless spiral wrap or stainless w/ stainless wrap.
A Dremel cutter wheel, at an angle, resulted in an acceptable shipping box length, for sending it to Fine Lines. I also painted one side, prior to the cut, to ensure proper orientation.
The replacement line arrived and I am very satisfied. I selected stainless line w/ stainless wrap. The Jeep uses metric fittings, so this is compatible with MB vehicles. It needed to have the shipping bend straightened and some other minor shipping smoothing.
Old Line - Master Cylinder End
![](http://i101.photobucket.com/albums/m52/wingless-pics/Jeep/94GrandCherokeeMSTRCYLOld.jpg)
New Line - Master Cylinder End
![](http://i101.photobucket.com/albums/m52/wingless-pics/Jeep/94GrandCherokeeMSTRCYLNew.jpg)
Old Line - Axle End
![](http://i101.photobucket.com/albums/m52/wingless-pics/Jeep/94GrandCherokeeAxleOld.jpg)
New Line - Axle End
![](http://i101.photobucket.com/albums/m52/wingless-pics/Jeep/94GrandCherokeeAxleNew.jpg)
94 Jeep
Old Line - Axle End
New Line - Axle End
94 Jeep
![](http://i101.photobucket.com/albums/m52/wingless-pics/Jeep/94GrandCherokee.jpg)
1 Post
The stainless brake line with stainless armor has been installed.
The brake line was close to the original, but it still required a coupla hours to change the shape to match the original.
Thank goodness I took LOTS of shots of the original. The images were captured at multiple orientations and angles. I would match my view of the new line to that on the image, then adjust the line 'till it matched.
Even with the tweaks required, I am still very satisfied with the service and the product.
New Line Installed - Steering Column Not Replaced
![](http://i101.photobucket.com/albums/m52/wingless-pics/Jeep/94GrandCherokeeMSTRCYLNewInstalledw.jpg)
New Line Installed - Axle End
![](http://i101.photobucket.com/albums/m52/wingless-pics/Jeep/94GrandCherokeeAxleNewInstalled5800.jpg)
