Seat Belts Don't Work
2003 S430
Described vehicle is a 2003 S430 outside the factory warranty period. I have been having some intermittent problems with my passenger side seat belt. Intermittently the seat belt will only extend out one or two inches at a time. In some cases I have to pull and retract the damm thing only inches and so very gently about 50 times just to extend it fully around my body before I can buckle it (no I am only 175 lb at 5'10") I took it to the dealer to have them look at this and they want $800.00 to replace the belt ($600.00 parts $200.00 Labor). Before I shell out $800 bones can any of you comment if this is something MB should cover under warranty because it's a safety related issue or do I bite the bullet?
Thanks in advance for your comments,
Rusty
Rusty
2010 ML550, 2010 E350 4M, 1966 Corvette Convt C2
You most likely have a bad retractor and that is what they want to replace. I am not aware of any extended warranty on these items. You do need to get it fixed if you have people in that seat. Just spring for the repair and ask the dealer to see if MB will eat any of the cost.
Most likely not the actual belt thats expensive but the retraction device and the labor to install it. Look the guy has an S Class and by now you might have figured out the more expensive the vehicle the more expensive the maint/parts/etc. Its all a function of the original, new, price of the car.
Sorry Sosh, A seatbelt retract mechanism is not a complicated mechanical device and no way worth $600. I am always amused by the analogy that because something costs more it's worth more to have it fixed. That's like saying the same set of tires should cost more for a Mercedes than for a Ford. Unfortunately, reality says you're correct.
Like I said..."reality says you're correct". I spent a career working in service and dealing with replacement parts costs. There's a limit to how much volume will reduce the cost of any part. Also, my guess is the identical mechanism is used in other cars with lower (and higher) sales volumes and don't cost as much to buy as a replacement part. Look, when I can buy the same part, with Mercedes packaging logos, online at 1/4 of the cost my local MB (is it Daimler now?) dealer is charging me I can safely say they are charging too much.
MBs
Model year 2003 introduces PreSafe into the W220 S-Class which uses a reversible active control retractor (ACR) on the front seatbelts, version 1, supplied by TRW. Picture:
![](http://www.whnet.com/4x4/pix/acr1.jpg)
http://www.trw.com/productsandtechno...E28188,00.html
Duval Motors lists the ACR for $274.00, slightly more than the ETRs in previous years.
http://www.trademotion.com/partlocat...?siteid=213951
Case closed.....although I didn't realize the ACR is that compicated. Still not $600 worth and this proves it. Doesn't it bother you that MB marks up the parts that much? With their volume and buying power (discounts) MB should be able to offer the part even lower!
MBs
MB parts pricing seems reasonable to me. It's just some local dealer parts departments, while very friendly, jack up prices unreasonably, sometimes way above list pricing. That's where Duval Motors, Germanstar, AutohausAZ, Caliber Motors etc come in handy.
Shouldn't the seatbelts and any mechanism related to it be under some sort of lifetime warranty because of the safety issue? I believe almost all companies have this policy, I am amazed MB doesn't have it... Are we sure?
