? about SRS light and suspension
my wife just bought an 03 sl500 a month ago that came with an extended warranty. the srs light was on and we were told that the warranty would cover it along with the drip near the left rear tire. we took it in and were hit with a $520 bill for the srs and $1300 for the hydrolic shock. i know the car is @ 5 years old but it only has 26000 miles. the extended warranty doesn't cover either.
any ideas how to ground the srs (passenger seat) if that would work. can the shock be rebuilt or something else. any ideas would be greatly appreciated.
2010 ML550, 2010 E350 4M, 1966 Corvette Convt C2
You said you were "hit with a bill". That implies that you had the work done and thats what you were charged. You must have an aftermarket warranty and a basic one at that. Read the warranty to confirm coverage, it may be worthless or a scam of the seller.
2004 E500 4matic
when I bought my car I got an aftermarket extended warranty too, however I did get it from a dealer I got mine after doing weeks for research on different aftermarket warranty companies fine print. Plus I used BBB.org to check the complains. I learn it best to use a large well known company bc it less of a chance the company going belly up. Also I found the most of the complains are due to the warranty company not paid for a repair. after a person fines complain some aftermarket warranty companies stand by there fine print "stating they must have preauthorization before repair is done.
we paid for the diagnostic. the car was purchased from an individual who had purchased the extended warranty when he bought it. i think we are the 3rd owner and the car is in great shape other than these problems. apparently they did something to the srs because the light does not even light up when the car is started.
here's what the invoice says:
connectors for srs for both seats and the strut assy nedds go be replaced. if we would of had them do the work it was going to be over 2 grand out of our pocket. the insurance company is mercury and the policy is the platinum plan which says that everything is cover accept certain things and the list is extensive. just so happens both are listed as not covered.
So it is a half assed aftermarket with loads of exceptions. Don't know why the original purchaser did not buy the MB warranty, perhaps price.... and now you are paying for it. Maybe if you go back after the seller who claimed it was covered he will do something for you. Sounds like someone intentionally disabled the system most likely to shut up the seat belt warning. As for the shock, thats a maintenence item even though its a low mileage car this some times happens. Do not believe it can be repaired but should be replaced. Repairs and maint of this vehicle are expensive so prepare yourself. However I would stay with the dealer who even though is more expensive per hour you do have warranty on repairs and are insured of getting the latest part number on replacements with genuine MB parts. I have also found that the bottom line is less or the same with an independent doing in many cases questionable work and using aftermarket or rebuilt parts. Good luck and enjoy your MB.
2004 E500 4matic
we knew about the srs light before we bought it but we thought the warranty covered it(didn't read the entire policy). anyway i think that it is the frustration of seeing such an expensive car have these types of failures with so few miles. plan on doing everything after the holidays. thanks for all of ya'lls help.
2004 E500 4matic
well good luck my friend.
