Airmatic problem - 2003 E500
Old Nov 24, 2007 | 05:36 PM
jamesbenz's Avatar
e500
Unhappy Airmatic problem - 2003 E500
I have a 2003 E500 w/67,000 miles. Today a red warning light started coming on and off, 'Car too low - do not drive' The front right appears to be lower than the front left. Any suggestions on what the problem could be? Any ideas of repair cost?
Thanks in advance for any suggestions/ideas.
Old Nov 24, 2007 | 09:51 PM
hammertime21's Avatar
2002 C32 AMG
Could be a leaking air strut, leaking air line/fitting, or air distribution block.
Old Nov 24, 2007 | 11:56 PM
jamesbenz's Avatar
e500
Airmatic problem
Thanks for your response. I've looked and listened for any air leaks, but cannot hear or feel any. I've also checked the fuses, (I think it's #37) but no problem there either. If it were a fuse I would expect the problem on all four quarters. Any ideas on how to trouble shoot? . . . or is it just a trip to the dealer and $$$
Old Nov 25, 2007 | 10:09 AM
Diesel Benz's Avatar
I would have guessed for a leak too. If it really doesn't sound like leaking, perhaps it is an Airmatic valve issue. A leaking strut would be pretty expensive, the control valve assembly should be less (but I have not checked the price).
Old Nov 25, 2007 | 10:23 AM
whoover's Avatar
'19 E63S sedan
Have it towed to the dealer. For one thing, it's not safe to drive (thus your display). For another, if there is a leak (and/or a bad relay, which is common), the pump will burn out from being run continuously and your cost will go way up. The Airmatic suspension is very complex and takes specialized expertise and equipment to repair correctly. And mistakes can cause serious accidents.
Old Aug 4, 2009 | 09:28 AM
dsm2925's Avatar
W211
where the airpump located? on a e500?
Old Aug 5, 2009 | 08:50 AM
vettdvr's Avatar
03 E500 and Corvette
Inside the right front wheel well behind the inner shield forward toward the bumper
Old Aug 13, 2009 | 03:43 PM
dsm2925's Avatar
W211
cant find it..
between the foglight and the tire? or between the tire and the right front door....
sorry guys new to this w211
Old Aug 13, 2009 | 04:50 PM
konigstiger's Avatar
'71 Pinto
cant find it..
front driver's side
File Type: pdf
Old Aug 13, 2009 | 04:55 PM
dsm2925's Avatar
W211
so this part goes attached to the sirpump?Attached Images
Old Aug 13, 2009 | 05:02 PM
'71 Pinto
PM your email address and I will send information include your VIN if you want a MB datacard listing initial delivery date, factory-installed equipment, etc.
Old Aug 13, 2009 | 05:34 PM
dsm2925's Avatar
W211
wow your best..
i will PM you now
