CEL and code P0306
Old Dec 22, 2007 | 05:19 PM
99MBSport's Avatar
1999 C280 Sport
CEL and code P0306
I know that this is a cylinder 6 no spark code. What would cause this. I have changed the plugs and switched the coil from another cylinder but I still get rough idle and code P0306. Could the spark plug wires fail that quick? Can I test the wire with an ohm meter? Thanks for all help you can supply to me. I have a 99C280 Sport.
Old Dec 22, 2007 | 08:58 PM
mleskovar's Avatar
'17 Jaguar XF
Originally Posted by 99MBSport
....I have changed the plugs and switched the coil from another cylinder but I still get rough idle and code P0306. Could the spark plug wires fail that quick? Can I test the wire with an ohm meter?
Did you change the plugs before or after getting the error code? Yes. Yes, but with carbon wires you could test OK with a meter and fail under load.
Old Dec 22, 2007 | 10:23 PM
211E350Black's Avatar
08 CLK350
compression on 6 is ok??
Old Dec 22, 2007 | 11:22 PM
99MBSport's Avatar
1999 C280 Sport
I got the error code then changed the plugs and switched the coils. Yes there is good compression on #6. This just started after a stop home after work. Thought that maybe the wires got wet. Going to try and switch wires tomorrow to see if it changes to another cylinder.
Old Dec 23, 2007 | 02:41 PM
Devilsfan72's Avatar
09 E63
Swap the injector with another one, see if it changes cyl.
