Gas octane boost
I know that on other newer cars it is a waste of money and can damage the O2 sensor. 91 octane is optimal for all new MBs even the C32 as the ECU controls detonation and the compression of the C32 isnt that high to need any higher.
2002 C32 brilliant silver, nav
Octane booster
Thanks, thats good info. I used the 104Plus in my boat and got good results, but that was a whole different engine set up.
C240 2002
Originally posted by mdp c230k
...91 octane is optimal for all new MBs even the C32 as the ECU controls detonation and the compression of the C32 isnt that high to need any higher.
In California the high octane is only 91, regular 87, and plus is 89 octane. All MBs are designed to run on 91 octane because it is the highest universally available. You are not hurting by using 93 but you are not gaining either.
Volvo V90 CC
1 Post
'06 Lexus GS300 RWD, '07 Camry SE V6 auto, '91 190E 2.6 auto
That's why I want to get my ECU reprogramed to use 93, so I gain something from using it.
Volvo V90 CC
Originally posted by Jim Banville
Won't the comupter automatically adjust for 93 octane? If the computer doesn't adjust and it is set to 93, what hapens if you put in 91?
If you put 89 or 87 you run a high risk that under heavy acceleration getting detonation.
ML500
That still didn't answer the ?... I'm in Fla, and we have 89 and 93 down here. Can you get the computer reprogrammed to be optimized with 93. I'm pretty sure there is no chip and that you would have to reprogram or replace the whole computer.
Oh, and 104 in my Go Cart gave it like an extra 10 mph, works great on weed wacker engines.
98 e430sport
Octane rating
I think it has something to do with altitude whether you get
93 octane or 91. In Colorado - I have never seen 93 octane.
Since the higher the octane number the slower the fuel burns, it may be that at high altitudes = less 0xygen/vol = 91 octane
at 5000 feet behaves same as 93 octane at sea level.
Asad
Asad
1983 300SD, 1996 C220, 1986 560SEL (my baby)
OK,
IF you are using 93 octane and your ECU is set for 91 - nothing happens
IF you are using 91, and your ECU is set for 93 - you're going to wear parts more
IF you are using 87 or 89 and your ECU is set for 91 or 93 - you're going to risk blowing an injector
IF you are attempting to use 104+ with ANYTHING - you're going to wear out parts that much faster, with minimal gains.
Volvo V90 CC
Originally posted by 560SEL
OK,
OK,
![Wink](https://mbworld.org/forums/images/smilies/wink.gif)
octane engine damage?
"IF you are using 91, and your ECU is set for 93 - you're going to wear parts more IF you are using 87 or 89 and your ECU is set for 91 or 93 - you're going to risk blowing an injector"
I don't believe these are accurate statements ...but I am not an engineer. More parts wear and injectors getting 'blown' (?). I believe the only problem caused by gas octane is possible detonation if the octane is too low...piston top damage, valve damage, power loss, and overheating.
Does anyone know if the ECU will adjust for octane deficiency or just notify you?
Like pocholin said. You risk detonation, detonation is the fuel/air mixture exploding before it should, the 93 octane trick reprograms the ECU and gives the car a bit more timing advance, 6 degrees over stock is what I've heard.
A friend of mine was setting the timing on a boat motor (Chevy 4.2L V6) without a timing light, while he was doing this he gave it a bit to much advance and blew a hole through the top of one of the pistons.
Also, the reason for our car being tuned for 91 octane is it just cheaper to make one engine for sale in all 50 states.
NP
NP
1 Post
2000 S500 Brilliant Silver, 1990 BMW 735iL, 1971 Pontiac Trans Am 455 HO, 1976 Pontiac Formula 400
MB tech?
Could you give us some insight as to how the MB's are set from the factory for the US as far as the ignition settings?
We have 93 octane in FL and some have said that there is a setting in the ignition correction program that advances the timing some, allowing you to take advantage of the 93 octane.
Is the baseline setting set conservatively by MB to protect against idiots putting regular gas in, or potential bad gas quality?
2002 SLK 320
Originally posted by rgleason
Where does one get 91 octane fuel? I live in Massachusetts. Regular is 87 octane, the mid grade is 89 octane , and high test is 93 octane. Is the 93 octane actually the 91 octane (just computed differently)?
In Europe it is near impossible to find fuels with octane ratings less than 93. If I remember correctly (correct me if I'm wrong) but the only octane ratings available are 95 and 98.
Originally posted by jswedberg
Remember that Europe defines their octane ratings differently - RON vs CLC - (or (R+M)/2).
I believe 98 RON is more or less equivalent to 93 CLC
93 (R+M)/2 is common east of the Rockies, and generally unavailable in the Rockies and West Coast. I don't know why that is.
We can get 94 (R+M)/2 at the pumps in Western Canada. It's popular with drivers of modified and older cars.
I wanted to mention that people using octane boosters should be very careful not to get the liquid on their skin, or to wash thoroughly and quickly if they do. I won't mention any brand names, but I remember one situation during a rally where a co-driver had a can of it spill into her bucket seat during a stage. There was naturally no desire to stop and clean up, and she wound up in the nearest hospital with symptoms that included circulatory and respiratory problems. Octane boosters can be toxic, quite volatile, and can quickly cross the skin into the bloodstream.
1 Post
MB Tech help please
Is there a MB Tech that can tell me what the US S class 2000 MY cars were set up for on gas octane? MB says to burn 91 US octane, but some areas may not have that, or if so, it may be of a poor quality. Is the baseline ignition setting for a lower octane gas as a margin of error to be conservative? Is the 93 RON ignition correction setting in the ignition program more aggressive than the baseline setting, allowing for more timing advance?
AMG C43, 1999
I had my ECU fuel setting changed to the 93 value about 4 months ago. My car is a 1999, C280-V6. I live in California and run 91 octane gas.
The only real change I note is that the midrange and lowend torque have gone up just little. Nothing to get real excited about, but the change is there.
No real advantage on the top end.
I put in 87 octane just to see what would happen and the car was less responsive but I could not detect detonation, so the ECU must have been picking it up and adjusting the computer.
Jeff
Jeff
