O2 sensors help W208
https://mbworld.org/forums/clk-class-w208/234619-oxygen-sensor-question.html
Ok I got my codes pulled and here they are:
PO100: MAF or MAP sensor condition
P0130: HO2S 11 circuit condition (Heated Oxygen sensor Bank 1 Sensor 1)
P0150: HO2S-21 circuit condition (Heated Oxygen sensor Bank 2 Sensor 1)
P0170: Fuel Trim Bank 1
P0173: Fuel Trim Bank 2 condition
I have already replaced the MAF a month as stated earlier BUT with one that I bought off of Ebay for 120 bucks. Could it actually be the MAF again since it is affecting both Banks??? I am at a loss on what to do...NEW MAF or 2 new O2 sensors??
edit: BTW those o2 codes are usually a result of when a lean mixture causes low voltage on the o2 sensors' signal wires. ME sees that as a bad sensor. MAF
The only question I have with this is that I am wondering if I should just buy some higher flowing cats like "Metal Cat" instead of using the CL55's cats?
Am I going the wrong way about this whole problem? My CEL light has been going on and off every day and I just want this thing back to normal (or better) if possible.
Thanks for the help so far!!
Greg
