Rebuilding Engine in '91 420 SEL
Im new to this forum and am looking for accurate information. I have been having a difficultly finding much of anything on the internet regarding specifications on my engine.
I have a 1991 420 SEL that has 173,000 miles. I purchased the car for school in non-running condition. The timing chain guides had broke. In a moment of brilliance I decided to rebuild the engine in class. The entire engine is torn apart and has been cleaned. I'm now ready to take measurements and decide what needs to be done regarding cylinders, pistons, and related parts. All of the parts were systematically removed and I know the original locations of all them.
Hopefully everyone will not mind my questions and ongoing use of this thread and I'm sorry for "stupid" questions. I am new to Mercedes Benz.
1. All of the cylinders have a ring ridge of .002". Is this acceptable to leave in the cylinder? Can it be honed? If honed, do I need oversize pistons or would wider rings work if available? Can the sleeve be bored (trying to avoid)?
-I don't want to resleeve the block.
That engine is so well engineered, there is no reason to ever rebuild one unless you've got a rod sticking through the oil pan. Did you notice that the cylinders are aluminum. There are no sleeves. You won't be able to duplicate that silicone finish in a hobby shop. That being said, reassemble the engine and just replace the bent valves on the left bank. Since it's apart, you may as well do a valve job on the right bank. The book you need is the M116/117 book for the 420 and 560 engine. Don't get the M116/117 book for the 350 and 450 engine. This is an MB pub and often shows up on ebay. Good luck.
Given this is a learning exercies and not a blueprinted race engine. I would let the students learn as much and then see the results.
Best of luck.
