s500 problem...........
Old Apr 27, 2008 | 12:01 PM
seamy's Avatar
s500
hi there....my first post and not a great start to mb ownership...
my s500 v8 wouldnt start for me today,it will turn over ok just not fire,then i let it sit for about 5 mins opened it as normal and it started first time,had a drive around the coast and was dropping a friend of at his house,we were sitting in the car with it ticking over...and it just stopped...now it wont start...anyone experience this? any help would be appreciated.....
thanks in advance.
seamy
Old Apr 27, 2008 | 01:59 PM
mleskovar's Avatar
'17 Jaguar XF
Not knowing the year I'm guessing CPS....Crankshaft Position Sensor
Old Apr 27, 2008 | 05:29 PM
OLDSCHOOLRICE's Avatar
07' E350, 71' DATSUN 510
+1
Im a tech, and this sounds a lot like a bad crank sensor. Very easy to change if you have the tools. About $400-$500 parts and labor at the dealer.
Old Apr 27, 2008 | 07:14 PM
seamy's Avatar
s500
its a 2000 car.......would a crank position sensor stop the car once its started and ticking over?
the car starts ok when cold,seems to be once its warmed up it wont start....
confused now..............
Old Apr 27, 2008 | 08:46 PM
mleskovar's Avatar
'17 Jaguar XF
Classic CPS symptoms.
Old Apr 27, 2008 | 11:01 PM
whoover's Avatar
'19 E63S sedan
Why confused? When the CPS goes, it's heat sensitive. That's why everyone is telling you it sounds like a bad CPS.
Old Apr 28, 2008 | 02:14 AM
Yes, as the engine gets hot, the internal windings inside the crank sensor go "open" due to heat expansion.
Old Apr 28, 2008 | 08:28 AM
vettdvr's Avatar
03 E500 and Corvette
Correct
Old Apr 29, 2008 | 12:35 PM
seamy's Avatar
s500
would this fault show up on the diagnostic then as a cps fault?
anyone got a pic of were this is situated on the engine....
thanks guys...
Old Apr 29, 2008 | 12:53 PM
whoover's Avatar
'19 E63S sedan
It's bolted outside the flywheet, near where the engine and transmission mate.
http://www.detali.ru/cat/oem_mb2.asp...SGR=075&SGN=04
The torx retaining bolt can be tough to get to without the right extension.
I don't know if it throws a code. Normally, hot stalling with inability to restart until the engine cools is all the diagnosis one needs.
Old May 7, 2008 | 03:40 PM
seamy's Avatar
s500
well,got the cps in on sunday and so far so good.....
thanks for the help guys....
