help with transmission service
Hello I bought a transmission kit for a 2003 e320 would like to change oil, filter and plug, is there anything i need to know before. anything to deactivate or disconnect? how many quarts should i put ?
03 E500 and Corvette
1) I could not get the drain plug out. I think it is a 5MM hex. Mine was stuck so I just removed the pan.
2) I measured the oil removed from the pan. The transmission tool to measure the fluid is basically a dipstick. If you have the dipstick do this engine running BEFORE you drain. If not don't spill any fluid then measure precisely what you removed. Mine was exactly 4 qts.
Part # 140 589 15 21 00 Dipstick You can sometimes find this on ebay.
3) Look closely at the bolts that hold the clamps on the pan. There should be 6 if I remember correctly. The clamps can go on 2 ways. The right way and the wrong way. Look at my photo,, you will see the drain plug and clamps on the pan.
4) Use only MB fluid from the dealer Transmission Fluid FUCHS ATF 28 (A0019894603
5) Be sure to clean the magnet and reinstall it in the pan.
6) Look for the fill tube. It will be on the lower part of the bell housing under the plastic air cleaner. It will have a rectangular cover black with a little T button sticking up. The T is a lock on the cap. Press it down and this should remove the lock and allow it's removal.
7) Don't confuse the oil fill tube with the transmission fill tube.
The transmission tube will run to the transmission. There are 2 and the oil fill looks like it might be the tranny fill due to location. It is not the tranny if it has a round cap. The tranny has almost a rectulangar cap with the T button about 3/16" wide. The T might be red or black.
8) Refill with correct amount of fluid and measure to confirm with engine running.
Total job is about 1 1/2 hrs Let us know how it turned out.
Transmission Tube Cap and seal 140 270 00 91
Transmission Red Tamper seal A 140 991 00 55
gl450 e320
On the fill tube the little T button broke off - how can I get the fill tube cap removed? I want to pump out the old transmission fluid an replace it using that procedure. E320 2003
Super Moderator
![](https://staticssl.ibsrv.net/autocomm/Content/MB/mbwambassador2.gif)
You really want to drop the pan
