Changing brake pads...
I need some tech help. im trying to replace my front pads on my 98 clk but for some reason i can take the claiper off. i alredy took off the two bolts behind the caliper and the brake sensor. am i missing somethig here? I am a nooB here on this board and am used to working on hondas. can someone give me a step by step procedure on how to do this? thanks
Brandon
Brandon
stuck brake pads
Try pushing the brake piston in a bit first. Usually the rotor wears in such a way that there is a ridge left around the outer edge that the pads catch on when you try to pull them off with the caliper.
