My A/C falls asleep?
Old Jun 21, 2008 | 02:09 PM
n00bert's Avatar
2004 C230 Kompressor Sedan
Ok here is my situation... it seems asthough my my A/C sometimes falls asleep... it will turn off completly and then after I mess with all the buttons it turns back on... it's the weirdest thing... anyone have an explaination for this? It only happens maybe 2 times a week... I never noticed it in the winter so the issue only seems to happen with the A/C on... it happens at random times sometimes when I first start driving and sometimes after 30 minutes or so. I'm so confused...
Old Jun 21, 2008 | 11:45 PM
Ausmbtech's Avatar
190D 2.5 (x2), 190E 2.6, W202 C240,W202 C43 (C55), W210 E55, W212 E250CDI
Do you mean that it stops cooling or that the fan turns off?
Old Jun 22, 2008 | 08:03 AM
n00bert's Avatar
the fans turn off till i play with the buttons for litterally a few seconds... i don't use the auto-climate control so it's not an issue with that
Old Jun 22, 2008 | 02:27 PM
ohlord's Avatar
With
these two on the hood the a/c can't keep up and has to shut down to cool off.
All kidding aside since you don't have the digital climate control like the E series,you can't run any onboard diagnostics to get sensor values and errors.
Time to get it on the SDS at an indie shop that has one.Call around and find a good mb shop (non dealer)that has the star diagnostic and they will find the problem.Might be just a faulty climate control module.
Stuck duo valve ,faulty evap sensor,several other things it could be and the only way to find out is the sds. or a trip to an automotive a/c specialist
ohlord
"GOT CODES?"
Attached Thumbnails My A/C falls asleep?-51773746.jpg
Old Jun 22, 2008 | 04:28 PM
whoover's Avatar
'19 E63S sedan
Sounds like the button assembly. I don't have any experience with that model, but an earlier S-class of mine did the same and they replaced the switch unit to fix it.
Old Jun 23, 2008 | 05:13 AM
Ausmbtech's Avatar
Sounds like the blower motor regulator or a/c control panel. See what fault code you get out of the A/C and go from there, the blower motor usually leaves codes.
Old Jun 24, 2008 | 01:16 PM
benz-tech's Avatar
BMW E30. I've turned to the dark side.
we hardly ever see pushbuttons go bad, it is most likely coincidental that the fan turns back on when you play with the buttons. most likely it is the blower reg. the blower regulator will shut down the motor if it sees too much amperage or blower speed (not sure how it knows the latter). it is true that a faulty blower regulator will set a fault code but 9/10 of all c-classes have that fault code with no customer complaints. measure the amperage of the blower motor- should be under 38A at full pop. there is an updated blower regulator that has a little more 'headroom' for blower amperage draw. as always my recommendation is to have it properly diagnosed and aviod throwing expensive parts at it- just as ausmbtech states.
