Cl 500 Fuel Door
2003 CL500
Cl 500 Fuel Door
If anyone can help? I have my 2003 CL500 for a week. I love it. I pulled up to the gas pump and the fuel door was raised. It would not stay down after a closer look I saw that a triangular "t" shaped piece had broken off. It appears that this piece wedges into a slot. Is this all that keeps it closed? Does anyone have any repair suggestions? PLease Help?
The door is kept closed by a spring that's integral with the fuel cap storage slot. The piece you're describing sounds more like the locking mechanism, which is not involved in keeping the door closed.
'03 CL500,& '18 GLS63. Gone: '83 500SEC,'99 500SL,'07GL450
![drive](https://mbworld.org/forums/images/smilies/driving.gif)
15 cls 550
The rubber leash that attaches the cap to the car has a habit of not rotating when you close the gas door. It keeps it from closing. Just turn it with your finger so it's not in the way. For a more permanent fix, drill out the hole in the leash a bit.
2003 CL500
Thanks for the informaiton. I played with the door a couple of times and then it started to close normally. Must have plastic cord from the gas cap.
CL500 and ML55
Turn the rubber teather so it is on top- then fuel door will close properly.
