PO173 code. need help
Old Sep 25, 2008 | 02:21 PM
soobieajax325's Avatar
1999 ML 320
Exclamation PO173 code. need help
so i have a ''''99 ml320. the check engine lights goes on and off sometimes. checked the vehicle for codes. got back a PO173 code. can someone elaborate as to what possible cause(s) that may be? i checked under the hood to see if anything was out of the ordinary. i found out that my passenger side valve cover gasket is leaking. might that set off the code?
Old Sep 25, 2008 | 06:18 PM
lkchris's Avatar
'10 CL550, '12 GL550
Almost always the air mass sensor.
Replace or try to clean.
Old Sep 28, 2008 | 08:15 PM
KarlBenz's Avatar
Mitsubishi Outlander 2012 AWD
I concur with air mass meter also change air filter and clean airbox small minute sand particles contaminate the air mass which for everyones infor the $90.00 insert is available instead of buying the whole $500 unit
