help 2004 s600 Trans Code p0730
Thanks!
P0730 Is gear ratio error, Ratios are calculated from reading N2 input shaft and N3 output shaft, located on conductor plate on the valve body. Wrong tire size, diffrent transmission and rear rations will cause Gear ratio error codes, have you changed any of these parts; more often then not it’s a defective conductor is the Cause. Any other codes, like wheel speed sensors, were ALL modules scanned
With a capable scanner you can verify speed sensor readings.
