Valve cover seal replacement
Old Dec 10, 2008 | 05:02 PM
CLK Operator's Avatar
Currently Benzless
Did anyone replace their valve cover seals on the 4.3 V8? If so how long of a job is it? Any special tools required?
I tried searching but found nothing.
Old Dec 10, 2008 | 07:21 PM
Gullwing's Avatar
1987 190E 2.3
Doesn't take very long. The dealer will ask an hour ish each side.
only tools you will need are.
T-20 torx
T-30 torx
E-10 inverted torx
Old Dec 16, 2008 | 08:00 PM
Currently Benzless
Thanks for the feedback. Does anyone know the part number of the valve cover gaskets? Also how much are they from a dealer?
Old Dec 16, 2008 | 09:42 PM
Quadcammer's Avatar
96 and 08 911 turbos
do you need the full gaskets or just the upper breather area?
Old Dec 17, 2008 | 11:21 PM
Currently Benzless
Anyone know the torque specs on the cover screws? Should I put anti seize on the threads?
Old Dec 18, 2008 | 02:09 AM
Gullwing's Avatar
1987 190E 2.3
I think it is 10 nm, but hand tight with a quarter inch ratchet should be fine, make sure all are about the same.
No anti seize is needed.
