Help! Idling Issue
Looking for a little bit of advice here. I recently purchased a vehicle from the company I work for (Enterprise Rent-a-car). I had a Mercedes dealership inspect the vehicle as well as a local shop my company uses. Both places gave the vehicle a clean bill of health.
However, recently I was driving the vehicle and while I was stopped at a stoplight the engine started to sputter and shake a little. The "Check Engine" light then turned on and the vehicle wouldn't go over a couple miles per hour. Luckily I was a block away from home and was able to coast in and call a tow truck.
The shop I brought my car to said the check engine codes were "misfires on cylinders 1 and 6." They said they believe it is dirty injectors. They put some injector cleaner in the tank and I'm still driving through what's left in the gas tank.
My question is, do any of you have any idea as to what may be causing my vehicle to idle rough and "shimmy" while i'm stopped or at a very low speed. It doesn't always get the shake, it seems to randomly happen.
***Note*** Just before the check engine light went off, the "reduce engine oil level" notification came on and then went away. Since that happened, I had the shop drain the oil and put 8 new quarts back in it. I don't know if that notification would cause what happened or not.
Any advice would be excellent. Service records from the carfax are as follows:
2001 C240 Sedan
101k Miles (Current Mileage)
109-Inspection and stardard maintenance done at time of purchase
100k Miles
Vehicle serviced at authorized Mercedes Dealer
96k Miles
Vehicle Serviced
Oil & Filter changed Chassis Lubricated
Manufacturer's Recommended Maintenance Performed
Spark Plugs Replaced
Rear Brake Pads & Rotors Replaced
Automatic Transmission Serviced
90k Miles
Front turnsignal/parking bulb replaced
Oil & Filter changed chassis lubricated
85k Miles
4-wheel alignment Performed
oil and filter changed chassis lubricated
manufacturer's recommended maintenance performed
81k Miles
Vehicle serviced
crankshaft position sensor replaced
engine/powertrain computer/module checked
stabilizer bar links replaced
75k Miles
Passed Emisions
74k Miles
Vehicle Serviced
oil & filter changed chassis lubricated
tire condition and pressure checked
4-wheel alignment performed
front brake pads and rotors replaced
spark plug wires replaced
More available if needed.
Thank you guys very much. Greatly appreciated.
From what I understand... there isn't really anything I can do to diagnose the problem until the CEL turns on again correct?
Yes, under the dash on the driver's side next to the steering column is a port that the OBD II reader plugs in to. Flip down a cover and plug it in and read the codes. Follow the OBD II directions for reading and clearing.
Not necessarily, but with the CEL then the codes are somewhat generic. MB can put it on STAR and be more specific in diagnosis, or not.
Do take care when fitting as the left and right HT leads do have different lengths and have different part numbers.
I will get an OBD II reader shortly and continue to monitor what happens and pursue the issue from there.
Thank you all very much. I have confidence in this vehicle again now.
