Alignment spec ?s for SLK32
Old Feb 9, 2003 | 01:04 PM
ldye's Avatar
2010 R8
Can anyone give me info? My 32 wants to dart around quite a bit. Have played with tire pressures and not much change. Talking with a shop foreman at dealer 2 hours away says he like to set the toe at -0- or negitave minutes. I had my alignment checked right after deliverly. The following are in degrees. Camber before LF -1.2, RF -.08, LR -1.5 , RR -1.3. Camber after alignment LF -1.0, RF 01.0, LR -1.4, RR -1.5
Toe before LF .19, RF .18, LR .43, RR .035 total toe front .37, rear.78.
Toe after, LF .18, RF .21, LR .28, RR .30, total toe front .40, rear .57.
Can my problem be helped by change the toe setting to 0 or negitave?
Old Feb 9, 2003 | 09:24 PM
Mercedes Tuner's Avatar
99 C43 AMG & 2008 Corvette 1LT Z51 LS3
What exactly do you mean by darting around?
Looking at your alignment specs they are about right. It does seem to me however that the front toe is more then it should be. I believe that front toe should be about 12 minutes toed in on each wheel for a total toe of 24 minutes. Rear toe should be about 16 minutes toed in at each wheel for a total toe of 32 minutes.
What are your Caster readings? You didn't post them.
Did you forget to put the Negative (-) symbol before the right front Camber on the after spec or was the Camber really changed that Much?
Looking at your Toe specs, I bet if you let go of the steering wheel that the steering wheel goes off center to the right a little?
Old Feb 9, 2003 | 10:39 PM
ldye's Avatar
2010 R8
Re: Alignment spec ?s for SLK32
[What I mean by darting is when you are on some roads with a very slight crown or groove the car will quickly jump. It may go to the edge of the road or to the center. I have to always drive mostly with both hands on the wheel to minimize the amount of travel. I know about trammeling and this is worst.
My printout does not have the caster settings. The tech said they were at spec. ]
Old Feb 10, 2003 | 08:41 PM
These cars are extremely sensitive to road variations!
Due to the stiff suspension, low profile tires and really short wheel base allows the car to change direction pretty quickly which is why the car is so sensitive.
One of the reasons why I asked what the caster is, if the car does not have enough caster it can cause this problem also. On cars that customers complain about this I usually add more positive caster to the car to increase its stability more and reduce some of the sensitivity.
Old Feb 10, 2003 | 09:39 PM
ldye's Avatar
2010 R8
Thanks for your reply. I'm going to have the tech check out the settings and see what he comes up with.
