Is This How The Tire Pressure Monitor Should Work?
Old Jun 17, 2009 | 12:00 PM
slk55er's Avatar
2024 GLB35 AMG, 2020 S560 Coupe
May I have your comments/suggestions on the following?
I was surprised when I installed one of my track tires/wheels (without a TPMS sensor) on the right front along with the 3 other stock TPMS wheels, that I did not get any warning message. Prior to installing this one wheel, the TPMS was active and apparently working normally.
When I had all 4 track/wheels without the TPMS sensors installed, I did get a warning message, although only after driving 20-30 miles.
I'd expect and hope that I'd immediately get a message if there is no sensor (or no air) in a wheel. If this is normal operation, I don't have much confidence in getting a timely warning of a significant air leak and rapid loss of air pressure. --- Comments?
Old Jun 23, 2009 | 11:33 PM
mbtech76034's Avatar
99 Z28 camaro 6.0
lack of communication is not what trigures a warning light. it's not like an open or closed circuit thing. depending on your system, it's your sensor picking up variations of wheel speed or pressure.
Old Jul 2, 2009 | 03:54 PM
MBTHEONE's Avatar
02 WRX
You will most deffinetly get an error message with rapid air loss. The tire losing air pressure actually triggers the sensor to send a signal stating so. We use that same idea for diagnosis of a sensor, you basically manually release approx .5bar I believe to be sure the sensor is reporting air loss.
Old Jul 3, 2009 | 02:07 AM
ESPoff's Avatar
LSX Camaro
ditto, the sensor has to see a rapid drop in air pressure in a certain amount of time that is diff from the other sensors.
