electronics shutting off, car switched to low gear
Old Oct 24, 2009 | 11:31 PM
ds968's Avatar
2003 mbz c 240
Hi, new member here - 2003 C-240
While driving on the freeway, the battery light suddenly came on, within seconds the radio and A/C turned off, other warning lights gradually appeared ( abs, srs ) , then the windows stopped working, the dashboad display led lights readouts ( odometer, etc ) got dimmer almost to the point where you can't see them, the car switched into low gear, so at least I can drive it slowly but NOTHING else is working.
What would be the most likely cause of this ?
Many thanks in advance
Dan
Old Oct 25, 2009 | 09:06 AM
Ausmbtech's Avatar
190D 2.5 (x2), 190E 2.6, W202 C240,W202 C43 (C55), W210 E55, W212 E250CDI
Most likely your alternator has failed. Usually it's just the regulator that needs changing, but sometimes the fault is in the alternator itself.
Everything turned off because there wasn't enought power to keep everything running.
Old Oct 26, 2009 | 07:25 PM
ds968's Avatar
2003 mbz c 240
Thanks that was it ( regulator most likely , possibly alternator ) but since the labor charge would have been the same and an OE rebuilt alternator/+ reg. was only $ 275 ( which I thought was reasonable price ) I had the alternator replaced.
Old Nov 12, 2009 | 04:25 PM
humgriju's Avatar
asf
How great your info is!But Can you give some more sample questions and answers.I really want to get more info about this topicIt really useful for me. Thanks.
