MBTECH208, please advise
Old Mar 11, 2003 | 01:03 AM
nduarte's Avatar
2003 CL 55 AMG
hello,
My 2003 CL 55 has the CHECK ENGINE light on. It has 504 miles on it. The light went off when i used the other key (#2) to start the car however when i put the other key (#1) back in to start the car the light reappeared.........
Old Mar 11, 2003 | 01:31 AM
mbtech208's Avatar
1997 Toyota Tacoma 4x4
Re: MBTECH208, please advise
Originally posted by nduarte
hello,
It was probably just a coincidence. The Check Engine light has nothing to do with which key you use. About the only thing you can do yourself is make sure the gas cap is on tight. Anything else will require a diagnostic trouble code readout.
Old Mar 11, 2003 | 01:08 PM
nduarte's Avatar
2003 CL 55 AMG
Does the light usually indicate it may be something major or minor....
thanks in advance
Old Mar 11, 2003 | 01:10 PM
nduarte's Avatar
2003 CL 55 AMG
oh im sorry i would also like to add that the light came on directly after i filled the car up with gas for the first time.....
sorry
Old Mar 12, 2003 | 01:33 AM
mbtech208's Avatar
There are hundreds of reasons for the check engine light to come on, ranging from meaningless to catastrophic. The fact that the light came on immediately after you fueled the car up leads me to believe you either didn't tighten the gas cap all the way, or you got a tank of bad gas. Then again, refueling may have had nothing to do with the light coming on.
Old Apr 3, 2003 | 10:46 AM
KOMPCOUPE03's Avatar
2003 C230 Kompressor Coupe
Or filled the gas tank while the engine is running which is a no-no.
