Winter Tire Recommended PSI - C350 4matic
2010 C350 4matic
Does anyone know what the correct winter tire PSI should be on the 2010 C350 4matic? My all season tires were 18", 35psi front, 38psi rear.
I installed the 17", 225 pirelli sottozero winter tire set on my car from a MB dealer.
I am trying to determine the correct pressure for this set? Is it the same 35, 38? I've asked a few delears, but keep getting different answers.
Maybe even if someone has a c350 4matic (2008 or later) with 17inch wheels, the psi should be similar.
Thanks!!!
Thanks!!!
2003 Lincoln LS V8
An easy way to tell is a chalk test. Draw a line of chalk across the tire, drive in a straight line for a short distance, then check to see if the line is wearing off evenly.
