Lowering modules
Old Mar 20, 2010 | 02:45 PM
mr Beenz's Avatar
s450
Lowering modules
Hey guys.. Which lowering modules do you think works the best and easiest to install ?
Old Mar 30, 2010 | 10:48 PM
mbtech76034's Avatar
99 Z28 camaro 6.0
This is something i am very interested in. however it seems that there may be a much cheaper way to perform this. It seems that on a vehicle with actual level sensors (airmatic, not abc) that you could just manipulate the actual values via resistors to lower the vehicle. that way your normal setting would be low, and your raised setting would be a factory ride height. Im curious if anyone on here has attempted this. I work at a dealership but have never seen these installed.
also, I've never done anything but correct ride height but we are able to calibrate ride height based on alignment angles at the dealership. maybe on a day that i have some extra time i will play with the suspension to see if this is feesible to have a lowered and stock position with just a trip to the dealership. of course then you would lose your option to raise your vehicle on the fly because that would now be your stock setting.
