C55 AMG Brakes and SBC System
Old Mar 23, 2010 | 08:20 PM
Scott Groft's Avatar
c55 AMG
I am the one yr owner of a 2005 C55 AMG. I need to change the fornt brake pads and would like to do this and the rotors myself. However, I have read numerous warnings on the SBC brake system. Can I do this project? How do I easily deactivate the SBC or can the work be done with causing the SBC system to activate?
I would greatly appreciate the help from the experienced owners.
Thanks!
Old Mar 23, 2010 | 08:25 PM
blair_mbz's Avatar
CLS55, C63, 997 Turbo
Scott,
First, I think you posted your question in the wrong forum. This forum is for assistance with the forum, not vehicle tech support. I'm sure one of the mods will move it.
But since you're here...if I recall, if you disconnect your battery for at least 30 minutes and leave it disconnected, that should disable the SBC system and you can perform whatever brake work you need to.
Old Mar 23, 2010 | 11:42 PM
MBTech51's Avatar
2007 ML350
the c class does not have SBC
Old Mar 24, 2010 | 10:59 AM
c55 AMG
Is there an easy way to confirm the SBC system? I have seen various web summaries that make it appear as though the C55 AMG has this system; however, they also reference the E55. All I see under the hood is a "pump device" with ESP on it.
When I look up the front brake pads, there is a "fit notice" that identifies the SBC system needing to be deactiviated for the C55 AMG.
Old Mar 24, 2010 | 04:42 PM
e1000's Avatar
a quarter mile at a time
C55's do not have SBC. Standard ABS braking system.
Old Mar 27, 2010 | 01:29 PM
kjb55's Avatar
2025 AMG E 53; 2018 GLC300 4Matic; 2003 360 Modena
Confusing BAS with SBC possibly? C55's have BAS - but it's no effect on brake work.
