can running on lo won gas cause p0443-po446-po1453
last night my gas light came on i got gas and drove home and it was all normal. this morning i turn it on and get display defective..
do you believe the low gas of last night would cause these codes to come up
p0443 p0446 p1453?
also i got new brakes less then 7k miles and my brake wear lights come on sometimes.. i look at the pad and it has alot left!
p0443 p0446 p1453?
03 E320 -wife's car now; 07 Porsche Boxster S - my toy
p0443 p0446 p1453?
p0443 p0446 p1453?
The EVAP monitor runs every drive cycle providing the initial conditions are met where one of the conditions is that the fuel tank needs to be within 15-85% full -- anything outside will not allow the monitor to run.
Since EVAP codes typically don't cause driveability problems, you should be able to drive the car to see if they clear on their own -- don't reset them -- let the PCM do its thing and test the EVAP system -- this could take a few days.
Regards,
paul...
thanks guys and no i didnt fill to top just half way.
i got my check engine and baseasr light on. but the codes i got are
P0443 Evaporative Emission Control System Purge Control Valve Circuit Malfunction
P0446 Evaporative Emission Control System Vent Control Circuit Malfunction
P1453 Secondary Air Injection Pump Relay Control Circuit Electrical
