84 190e will crank but not run help please
Old Apr 6, 2003 | 09:51 PM
roscoe27020's Avatar
84 190e
Car will run for about a minute then cut off and then you can crank it but it will die just as soon as it starts running. If you let it sit for a while it will crank and run again or about a minute then the same thing. Also the is a clicking noise coming from what I belive is some sort of relay. It is a black box at the top of the fuse panel under the hood on the driver side. It clicks even after the car is turned off and key is removed. Thanks for any info on this problem.
Old Apr 13, 2003 | 11:08 PM
230KBenz's Avatar
'03 C230K
what does it say on the black box? That noise isnt normal you probably need a new one, which side of the engine bay? If its E-gas or fuel pump relay, or overvoltage protection relay if on right side(passenger side)
2003 C230K magma, C5, C7, 6spd
Old Apr 15, 2003 | 12:30 PM
84 190e
It is on the driver side in the back of the motor compatment. It is with all of the fuses. I am pretty sure it is a reley for all of your electrical parts like fuel pump etc. In side the the car in the console there is a red toggle switch if i press it on way the clicking stops the other it will start back. Thanks for the help.
Old Apr 15, 2003 | 08:37 PM
230KBenz's Avatar
'03 C230K
the fuel pump has its own big huge relay on the right side of the engine bay, this could be a possible cause of your problem cause they do strange things when they go bad, it will cost about $170 , just letting you know. If you have a red toggle switch thats not for the 4-ways then somebody must have been doing something funny with something that dosnt belong there.
