95 500SL Operating temp 110, changed radiat. & thermo-did not help, any ideas???
1995 500SL & 2001 CLK 430
Please help, operating temp 110 under normal driving conditions, A/C on, all fans working. Replaced radiator and thermostat, no change, I can turn on Full Heat and it will drop temp 5-7 degrees, seems like water pump is working fine, any suggestions????
Thanks, Ron
Thanks, Ron
SL600 r230, SL600 r129,, SL500 r230, ML320, C280 Sport, 190e 2.3 16V (2)
Are you certain the gauge is accurate?
Even with the radiator fans running, you go to 110c? And it stays there?
What antifreeze are you using, and have you checked concentration?
2004 Ran SRT-10,2007 S550,2016 E400c
What did the old coolant look like rusty?? Could be lots of things.. Check with infa-red meter to se if you have any blocks, heater core could be block..
Make sure water pump is working fine ( moving water)
Check fan clutch... when hot there should be very minimal slipage..
It has a duo valve ( heater core shut off) this can stick.
In the end it can have a bad gauge.. make sure with a infrared therometer the coolant is at that temp.
Runs at 110 C, which is 230 degrees even with all fans working. Coolant is about 90% concentration and is super clean, no rust.
I have someone checking the temp senser and guages for me now, i hope it's that simple. My Merc. Mech looked at it this morning and he couldnt believe the temp was 110 and the car had not overflowed thru the radiator cap yet, he also mentioned the top radiator hose did not feel as hot or pressurized as it prob should if that temp is correct. His main concern was cracking the head if the temp goes any higher.
You do realize that antifreeze has less heat conductivity than water? For warm weather, go 50/50.
But I doubt that is your problem.
2017 E300
2010 ML550, 2010 E350 4M, 1966 Corvette Convt C2
Most likely its the anti freeze percentage. Too high will cause it to run warm or even overheat. No more than 50/50 is suggested. Other scenarios are possible but unlikely.
