Help - Replaced Keyless Go Shift Knob
In lieu of that, do you know how I can remove the keyless go switch in the knob and put it in the new knob? (I changed knob because of worn out leather not functionality)
Take the knob apart - take off the chrome plastic thing that locks the knob to the shifter. You just turn it and work it off. Then there is a black plastic ring-sleeve where the chrome thing twists and locks onto. Take 4 paper clips and insert them around the inside edge of the ring-sleeve. This keeps the retainer "hooks" set in so you can now work the center part of the knob from the outer part of the knob. You'll really have to twist and pull and even insert a small screwdriver between the two parts of the knob (if leather and wood knob, this is the boundary between the wood and leather. Once the knob is separated into two pieces, turn the top piece over and you'll see two torx driver screws - really small. If you don't have a torx driver that small, just use a philips screw driver. Once the screws are out, look for 4 small holes (on the same surface as the screws. Insert a philips screwdriver thru the holes to push the stop-start switch out of the top of the knob.
