Problem with Fog HID's Tech please help!
I have gone back and forth 3 times between the dealer and the shop where I got my HIDs for the fog lights installed. The lights are still going on and off and neither of them have a solution for it. I have spent 2 days at getting them to work and nothing. Any of you who have HID kit for the fogs, was it as much trouble as this?, did the dealer have to do anything special?, has any of you had this problem? and is there a solution? THX!
you will need to wire the power side of the lights directly to the battery. in otherwords you will need to bypass the factory wiring to the fogs. the easiest way to do this is to use the factory wires to trigger two relays, one for each side, and hook the other side of the relays directly to the battery. basically use seperate relays to trigger the lights.
