E350 Timing Gear Failure
Old Feb 15, 2011 | 02:44 PM
bzinser's Avatar
2006 E350 4Matic Wagon
2006 E350 4Matic Wagon - 80k miles, CEL - took to dealer and informed a cam timing gear failure. $1500 kit plus 33 shop hours - Approx $5,700 total. Checking appears to be fairly common as Dealer Technical Bulletin has been issued on problem. Has anyone had this repair done? Also, has anyone ignored and driven - how long before timing gets so bad car will not run or operate?
Any information on success of repair would be appreciated.
Old Feb 18, 2011 | 10:05 AM
jayz's Avatar
2003 S430 4Matic
You may have the x50 series engines that have a composite timing gear. Mercedes is aware of failure problem and has serial numbers of affected engines. My mercedes dealer found out that some models will not pass emissions inpections even with slight wear. He said engine must come out to replace timing gear on 2006 ML's.
Also, use the forum search to see the posts regarding "2007 S550 engine problems"
Old Mar 4, 2011 | 09:32 AM
jayz's Avatar
2003 S430 4Matic
More information on balance shaft gear problems:
http://classactionlawsuitsinthenews....-m273-engines/
Old Mar 16, 2011 | 11:10 PM
BadBird99's Avatar
CLK550
As mentioned above it is a very serious repair. On 272 a balance shaft must be replace in order to correct the problem. On 273 its just a cam gear.
I would not ignore this fault, because eventually cam gear will become rounded of and cause timing to jump, causing further damage to the engine.
Have you talked to the dealer about Goodwilling the job?
Old Mar 31, 2011 | 12:27 AM
mbwhat's Avatar
1985 300cd 1994 E320 cab.
ha ha mercedes made the gear with weaker metal than the chain good job mercedes
Old Apr 4, 2011 | 06:58 PM
rmfnla's Avatar
2013 Infiniti G37 Coupe; 2011 GLK 350 w/ Premium 1, Multimedia & Sport Appearance; I LOVE IT!
These issues contributed to MB's decline in perceived quality after the year 2000.
