DIY Transmission oil and filter 1999 C280
Old Mar 6, 2011 | 07:23 PM
ruzhkata's Avatar
Mercedes Benz C280
Could you please help me, I'm going to change my transmission oil and filter probably gasket as well for my 1999 c280. I've done it on a few automatic cars, is it the same on Mercedes? I noticed I don't have a dipstick and at the stealership they told me it'll be like 70 bucks. How much oil do I sip?
Old Mar 7, 2011 | 10:03 PM
ohlord's Avatar
Diy
for trans fluid change
www.benzworld.org w210 forum
722.6 transmission
MB spec fluid rated 722.6 or valvoline maxlife 722.6 nag1 spec.
Filter and gasket set on www.autohausaz.com
Dipstick and pan magnet from some member around here
Depends on how much of a change you do differing by procedure how much fluid you will get out and put back in, fresh.
Old Jan 28, 2012 | 05:25 PM
keityd's Avatar
1997 C280
what type of tranmission fluid is used in a 1997 C280 mercedes
Old Jan 28, 2012 | 08:07 PM
DerekLMartin's Avatar
1998 VW GTI
On 722.6 transmissions it is usually a good idea to change the pilot bushing as well. They always leak, and the oil can travel up the harness and cause all sorts of problems.
Old Feb 13, 2012 | 10:43 PM
jamster's Avatar
2012 prius
722.6 trans takes around 4.5qts
