ML W164 backup camera option 218 Retrofit HELP
Old 05-05-2011, 06:33 AM
hercules's Avatar
W203 C200K-2003
OK, this has been posted previously and I'm asking for expert or Guru advice and knowledge in this forum about this retrofit in which I am having problems.
I have retrofitted the backup camera control unit on a ML W164 2006 option code 218.
The following equipment code has been documented for the vehicle in VeDoc: SA code 218 (Backup camera), SCN coding for control unit Instrument cluster has been performed but no extra menu is available in the IC.
An initial startup is performed but the system is not able to save calibrations of the passive graphic lines or steering angle .
Any suggestions or comment will be very much appreciated.
Edit/Delete Message
Quick Reply: ML W164 backup camera option 218 Retrofit HELP
