Wierd Vibration
Old Jun 22, 2011 | 08:33 AM
aintez's Avatar
E500 2002. Supra TT 97, Supra NA-T 94, Glanza 96, Starlet 90
Wierd Vibration
Hi guys
Lately i started getting a wierd vibration in the car, i think it has been happening for a while now but i used to think it was a bad patch of the road. Now i think it is happening much much more in frequency and amount.
Why do i say it is wierd ?
Well it seems to come when on a very slight load, eg going up hill slightly, slightly accelerating.
I first thought it was wheels but it doesnt happen at a specific speed or cant feel it much through the steering wheel.
So hoping its not the transmission but thinking it could also be diff, trans mounts or diff mounts.
Reason im not convinced it is mounts is it happens at a specific low load point. So thinking something like a valve in the transmission may be sticking. Also there is no noise heard, just the vibration felt throughout the car.
When it doesnt happen ?
When engine is somewhat idling (offload) decelerating (regardless of speed)
Full acceleration
Mild Acceleration
Low speed (seems to be most prominent in 4th gear)
Car is an E500 (2003)
Would appreciate any help at all !
thanks
Old Jun 24, 2011 | 08:49 AM
aintez's Avatar
no one ? :P
Old Jun 25, 2011 | 01:02 AM
tcesario's Avatar
09 E350 ,
sit at idle in n and take it up to 3ooo rpm if you feel it in the seat it is the trans mount ,start there it usaully fixes that issue.
Old Jun 25, 2011 | 01:03 AM
Ausmbtech's Avatar
190D 2.5 (x2), 190E 2.6, W202 C240,W202 C43 (C55), W210 E55, W212 E250CDI
If it's just under light loads, usually slightly uphill, usually 2nd or 3rd gear at about 1500-2500rpm. It may also only do it when it is hot and not when cold. If this sounds about right then I would suggest you do a search for coolant contamination in the transmission (w203 forums will probably have more info on it)
Basically the transmission oil cooler in the radiator leaks, coolant goes into the transmission and the shuddering is the torque convertor clutches.
Basic solution is new radiator, flush the transmission and hope you caught it early enough. Don't wait to see if it gets worse, at least get a oil sample from the transmission tested.
Old Jun 27, 2011 | 10:05 AM
aintez's Avatar
Thanks guys
Doesnt happen when i idle and then rev up, had a look underneath and doesnt seem to be any problem with the gearbox mounts or rear diff mounts, need to check engine mounts next and then probably gearbox or torque convertor maybe ?
Originally Posted by Ausmbtech
If it's just under light loads, usually slightly uphill, usually 2nd or 3rd gear at about 1500-2500rpm. It may also only do it when it is hot and not when cold. If this sounds about right then I would ......................
Nah happens both hot and cold,
Hope its not the gearbox though but doesnt make sense that it would be
