Oil dipstick for 03 E320
Old May 31, 2003 | 02:53 AM
asdf's Avatar
Does anyone know if there's a dipstick for older E that I can use for the 03 E320? Part number would also be vey helpful.
TIA.
David
Old May 31, 2003 | 07:13 AM
amdeutsch's Avatar
Administrator
MPG+ ROLFCOPTER
Re: Oil dipstick for 03 E320
TIA.
David
If your tube is located near the firewall you might want to check out this thread. The engines are the same. Prices vary from dealer to dealer.
If your tube is located in the front of the engine the MY02 dipstick should work for you.
You might want to use
for more info.
Old May 31, 2003 | 10:02 AM
asdf's Avatar
Thanks. Amdeustch.
Mine is near the firewall, so I can use your part.
Any update on how the seal is now?
Old May 31, 2003 | 11:19 AM
amdeutsch's Avatar
Administrator
MPG+ ROLFCOPTER
I have not seen any leakage on the tube or the dipstick. I also checked for hot gasses blowby and couldn't find anything on either the engine, the firewall or the underneath side of the hood.
