dash bulb replacement ??
none
I just got a 93 600SEL and have a couple of bulbs out in the dash behind the clock, light switch, right side vent controls, left side climate control, and shifter.
How do I access these lights?
1986 560SEL, 97 BMW 740iL
Well, there is a tool you could use to pull the dash display unit out. First, move the steering wheel away from the dash as far as possible and then pull the dash unit out. Behind the unit, you'd find which bulb needed to be changed. If you need to unplug the unit from the car, it's pretty straight forward. Afterward, push the unit back in and see if you corrected the problem.
1 Post
'04 Silverado Z71 - sold all my Benzes and need another!
This is what the cluster removal tools look like. You can also shape a couple pieces from a wire hanger to do the job just the same. I have seen these tools sold on ebay from time to time.
1 Post
Originally posted by Raul J. Carrasq
Where are you supposed to insert this tools, I have an S320-1994 and have been trying to find the insertion points.
1 Post
Originally posted by kennygss
Intresting thread guys! My 97' E420 has no illumination in the climate controls module. Is that lit by a light behind it as well??
