2008 C300 Check Oil at Next Refuel Alert Keeps Bugging Me
![Red face](https://mbworld.org/forums/images/icons/icon11.gif)
Hi guys,
New here. Sorry if this is posted in the wrong section.
My 2008 C300 has been running fine for three years now. I bought it at 4 miles and it's still with me. Lately it's been having some annoying issues and I'm wondering if it's because my Dad and I decided to do the AB service at home. We tried to DIY it to save some cash. Money's been tight lately.
We changed the oil ourselves about a few months ago (Back in July). But lately I've still been getting that annoying "Check Oil at Next Refuel" alert. I check the oil level every time (yes, after car's been off for half an hour, etc.) and it's fine! Even dropped in a little oil from time-to-time to make sure it's alright. But still, with every tank of gas I get that stupid alert coming on once.
I should mention that this alert happens when I'm driving long distances. I am only able to do this probably about once a week, since most of my daily commute is in traffic and I take the bus on the weekends (I live in the city). Engine temperature seems fine, around 80 degrees.
Any idea what might be up? I did some research and found this is a common occurrence with the model refresh. But I really want to avoid taking it to the dealer if I can. Simply put, those guys can be crooks, and sometimes they don't help at all (but still charge you an arm and a leg).
Complaint:
Oil message "Check oil level at next refueling stop" appears on instrument cluster
Cause:
Various causes, see remedy below
Remedy:
1. Check oil level (at >85 °C engine oil temperature):
a.) Oil level OK (oil level clearly above minimum mark). Continue with step 2
b.) Oil level not OK (oil level at or below minimum mark), correct oil level. No further measures required
2. Check coding of engine model designation/oil data record in ASSYST:
a.) Coding of engine model designation/oil data record OK, continue with step 3
b.) Coding of engine model designation/oil data record not OK, correct coding. No further measures required
3. Check oil level switch at different oil levels (minimum and maximum) using DAS test step/socket box:
a.) Oil level switch OK, continue with step 4.
b.) Oil level switch not OK, replace oil level switch (observe parts ordering notes)
Note:
The oil level must only be measured via the oil level switch in the following operating state:
- Oil temperature > 85 degrees Celsius
- Rpm range 1000 - 1500 rpm
- Measurement duration: min. 60 sec.
4. Check installed oil dipstick:
a.) Installed oil dipstick OK, no further measures required
b.) Installed oil dipstick not OK, replace oil dipstick. No further measures required
Cause:
Remedy:
Note:
