HELP MY CAR PASS AIRCARE PLEASE!!!!
Old May 22, 2012 | 03:42 AM
jimmmmy's Avatar
560 sec
i have a 1991 560 sec i have failed air care 4 times thinking about trying some methol hydrate this time around. I already had a new cat installed along with new plugs and O2 sensor... what els can i do? should i go with the MH i was told to fill up around 10L of gas and put 1l of MH then drive for around 30 min before taking it in..
to see the air care results type in my vin to this link
http://www.aircare.ca/inspinfo-get-results.php
VIN- WDB1260451A607941
the first fail is before i got the cat installed the 3 after are a little bette but im still failing
Old May 22, 2012 | 01:01 PM
jimmmmy's Avatar
560 sec
over 400 views and noone can give any advice at all??
Old May 23, 2012 | 02:22 AM
Ausmbtech's Avatar
190D 2.5 (x2), 190E 2.6, W202 C240,W202 C43 (C55), W210 E55, W212 E250CDI
Have you checked your fuel mixture? Does it drive ok? Does if misfire at all?
Does your engine get to full opertating temp?
Old May 23, 2012 | 11:31 AM
jimmmmy's Avatar
560 sec
thanks for your reply!
I have always used regular gas is that ok?
It drives fine but shakes a little on idle
it never misfired
yes it gets to full temp
It has a strong smell of gas I get a little white smoke sometimes but nothing major. It's an import from japan with 73,000 but the spedo stopped working so I'm thinking it has a lot more than 73k..
Old May 24, 2012 | 03:24 AM
Ausmbtech's Avatar
Your high HC is unburnt fuel, if you can smell it then it's a problem.
These engines should be pretty smooth at idle.
To minimise your out of pocket expences I'd just replace the spark plugs (use standard copper plugs correctly gapped, they dont like expensive plugs), clean the distributor cap and rotor and adjust you fuel mixture to correct specs. A bit of injector cleaner might help too but you may find they are getting close to replacement anyway.
Old May 24, 2012 | 02:01 PM
jimmmmy's Avatar
560 sec
great! thanks so much for the info.
what type of gas should i be putting in? Gas is crazy expensive over here (vancouver canada) i was told regular is fine? should I put in a higher grade to help it pass aircare? what about using methol hydrate? do you think that would help at all or should i just try the things you said first?
Thanks again!
