How Is This Possible?
Driving down the Fla. Tpk. doing 75 mph. Suddenly the car vibrates, grindes and shakes as if I'm riding over gravel. I believe I have a flat and immediatly pull over. I check to see which tire is flat and notice a small amount of liguid eminating from the passanger side of engine. Engine is off and I open the hood to look for leak. Notice nothing. Try to start engine with hood up and the battery makes a loud POP, a piece of plastic from the battery casing hits the upraised hood and I realize that the liguid is the battery acid. The battery has blown up. Car is dead and will not start. Also, transmission will not hold in park. After towing to MB dealership, dealer tells me transmission is cooked, SBS system is cooked and battery has blown.
Here's my question.
How can a blown battery fry the transmission? Why wasn't the alternator damaged or for that matter anything else. Why was there no indication on my dash? No bells or whistles, no warning?
Dealership tells me this is a freak incident, however, batteries have been known to explode occasionally. Chances of this happining again is like getting hit by lightning.
This doesn't help to build my confidence level. The damage will cost me $6000. I'll get a new warranty on the tranny (2 &1/2 yrs) and one year on everything else. This helps a little but I want to know how a blown battery destroys a tranny.
Can anyone tell me?
Thanks for your help.
If I were you, I would talk to the Service Manager and ask to have a MB Factory Rep come in to examine your car as it sounds like your dealer is not sure what happened and is trying to grasp- at-straws to explain your situation. Your Service Manager/Advisor probably will resist, but I would insist on it before spending $6K on a repair. You never know. If the factory rep gets involved, he/she may find something or may be awair of a TSB (tecnical Service Bulliten)/Recall that explains your situation an maby you will get some assistance crom MB Corporate.
Good Luck! Let us know how it works out.
MB Transmissions before 1998 were not electronicly controlled...
And without the electric/electronic controlling system the transmission can only shift to 2nd gear and reverse (only hydraulic). If it is in another gear and something happens it stays in that gear.
no the tranny fluid is pumped by the torque converter...
The transmission oil pump has nothing to do with the torque converter.
your vehicle is run by the battery. the alternator charges the battery and the voltage regulator regulates voltage to the battery. on our cars and really any new computer controlled car, you CANNOT remove the battery from the system without frying the internal voltage regulator in the alt and probably a few other things.
Also;
Transmission Driver-adaptive electronic 5-speed automatic. Driver-selectable winter mode starts vehicle moving in 2nd gear or a second Reverse gear to help improve take-off on slick surfaces
Mercedes-Benz is asking owners of all 1998 and some 1999 C Class models to bring them to dealers so they can check the battery fluid. If the fluid is too low, it can expose electric plates and ignite gases inside.
"We're not necessarily going to be replacing them, in fact in most cases we won't be," Mercedes-Benz spokesman Fred Heiler said. "There is nothing wrong with the battery if it is maintained correctly."
At least five owners have reported their battery exploded. One person was injured by spraying acid and battery fragments. Mercedes-Benz dealers will put warning labels in the owner's manual and engine compartment saying the battery should be checked during every tune up.
