!989 300E sways
SPONSOR
Answer
In almost every case you will need to replace the following additional parts.
Joint, x2
MB# 2203520227
Rubber mount, x2
MB# 1243511342
Rubber mount, x2
MB# 1243527765
inspect the following and replace as needed.
Rubber mount, x2
MB# 2023520165
http://www.peachparts.com/shopforum/...ulti-link.html
If you feel it in your HANDS and FEET, the front steering suspension has serious issues.
SUSPENSION:
* Front Shock and Spring Replacement: Pelican Technical Article: Mercedes Benz - Front Shock and Spring Replacement
* Front Wheel Bearing Replacement: Pelican Technical Article: Mercedes Benz - Front Wheel Bearing Replacement
* Rear Shock and Spring Replacement: Pelican Technical Article: Mercedes Benz - Rear Shock and Spring Replacement
W210 DANGEROUS FLAW please read (crosslinked in post #1 to all on topic data)
My spring perch failed. This is a documented problem on the W210 cars; NHTSA has four cases they are investigating. There is another thread in tech section for more info, but if you have a W210 PLEASE check your perches because you could be KILLED if they give way on the road!! It is a pain but I implore you to get it checked!! The wheel and spring COLLAPSE and cause one side of the fromt to LOCK UP; you can imagine the loss of control!! DO NOT PUT IT OFF you may save the lives of your family or other innocent drivers. I cannot believe that MB is not RECALLING these cars! Sure it's costly but so is a wrongful death suit - could be hundreds of millions if the car hits a schoolbus for instance! They will have to recall these cars at some point but in the meantime people will DIE!
I cannot overstate the importance of getting YOUR car checked!! PLEASE!!
http://www.peachparts.com/shopforum/...opic-data.html
roy@pelicanparts.com
