Please Help! Abs/ Brake Assist Problem
![Unhappy](https://mbworld.org/forums/images/icons/icon9.gif)
Hi everyone, I'm new to the forum..my name's Danny and I own a 2001 E320...Alright, heres the problem.. so my rims just came in, 19 x8.5, 19 x 9.5 moven brabus mono 6 replicas. I was told that my stock lugs would work fine. So I went ahead and mounted them. The lug went into the rotor about 1.5inch. Then when I start the car, the abs light as well as "brake assist" light comes up and the screen says "visit workshop, bas error"...
I had a feeling the bolts were too damn long. So I replaced the rims again with some stock W202 rims, I also used my stock W210 bolts, but with those wheels the lugs only goes into the rotor about .75 inch, yet I was still getting the error lights when I started the car...
My questions are:
1.Is it possible to damage the ABS/brake assist mechanism JUST by screwing in a bolt that is too long? Because I know if you drive the car it will mess up for sure but I didnt move the car an inch, just drove in the screws too deep.
2.Is there an ABS/brake assist mechanism on the front rotors? I was told only the rear mattered.
3. How short of a bolt can I get in order to clear the ABS yet still remain safe?
4. What do you guys suggest I do?
Right now the car is just sitting in the garage, movens on the front, stock w202 wheels on the rear, ABS light is still coming on.. I am very hesitant to even drive it to the shop because my friend one time torn his abs system apart when using aftermarket wheels with factory bolts. The car is a 2001 E320..Any help that anyone can give is very much appreciated. Any advice please give me as well.
Thanks everyone for trying to help me out. its very appreciated.
Danny
My questions are:
Danny
Maybe if you use the standard equipment you would not have those problems?
I'm pretty sure that your Brabus wheels may not be mounted on your type of car.
I guess it is not a new E yet, so it will be model 210.065.
The largest you are allowed to go is 8J x 18 H2 ET31 with 235/40 ZR 18 tyres.
So:
"1.Is it possible to damage the ABS/brake assist mechanism JUST by screwing in a bolt that is too long? Because I know if you drive the car it will mess up for sure but I didnt move the car an inch, just drove in the screws too deep."
Only if they are much too long, but a child could see that.
"2.Is there an ABS/brake assist mechanism on the front rotors? I was told only the rear mattered."
If they are talking about the rear, it is about the parking brake mechanism.
"3. How short of a bolt can I get in order to clear the ABS yet still remain safe?"
Pick your 210 standard wheels, put a standard bolt trough it and you will know it.
"4. What do you guys suggest I do?"
Use standard equipment or at least MB permitted wheel dimensions.
And...maybe you damaged the ABS sensor wiring?
So:
