1990 300e oil burning Problem
1990 Merc 300e sedan
Hello all,
I have had my 300e sedan for a very long time now and I just noticed that it has started to burn oil in the last month or so. Now it had never done this before. I moved to AZ a while ago and notice a change in the car. The car only has 65k on her, she does not get driven alot, So I dont know where it could have started?
There are NO leaks in the drive way or in the garage what so ever but I have had to put a qt. of oil in it more often then I would if I was back home. IDK what it could be. If there is anyone out there that can help That would be sweet.
190D 2.5 (x2), 190E 2.6, W202 C240,W202 C43 (C55), W210 E55, W212 E250CDI
Most common oil consumption on a M103 is from weak or damaged valve stem seals. Is job to do in car, there is a pdf tutorial floating around (google search, I think it's on another forum). I've seen some that the stem seals have dislodged which causes a sudden increase in oil consumption.
![Question](https://mbworld.org/forums/images/icons/icon5.gif)
Thank you sir I will have to look into that and see if that's the cause of why its doing that... Now just for the sake of asking would there be anything else that I would have to look into if it turns out that's not my problem?
